Issue with Keil V4.74
Dear All,
I have encountered a problem in simulating the following code on MDK-Lite Keil version 4.74.022. The ISR routine is not being executed during simulation with Keil V4.74 evaluation version only. This code runs on hardware and on Keil V3.36 simulator. I don't know what may be wrong with my MDK-Lite Keil version 4.74.022, maybe start-up file, but still don't know how to fix it.
Thanks for your help.
#include <LPC21xx.h>
#define LED (1<<0)
void Trigger_EXT_Int(void) __irq
if( (LED & IOPIN0) == LED)
        //checking the state of the pin
  IOCLR0=LED;
else
 IOSET0=LED;
   EXTINT=LED;          //CLEAR EXTENAL FLAG FOR EXTINT EGISTER
   VICVectAddr=0x00;
int main(void)
PINSEL0=0x0000000C;      //set P0.1 as external interrupt
PINSEL1=0x00000000;
IODIR0=0xFFFD;   //set as output P0.0
EXTMODE=0x01 ;   //edge sensitive is selected in EINT0 pin;
EXTPOLAR=0x0 ;   //active on negative edge on P0.1
VICIntSelect=0;  //CLASSIFIES INTERRUPTS AS EITHER FIQ or IRQ.Put a 1 for FIQ or 0 for IRQ.
VICVectCntl0=14 | 32; //channel 14 is for ext int| enable bit 5
VICIntEnable=0x00004000 ;
VICVectAddr0= (unsigned long)Trigger_EXT_Int    ;
IOCLR0=LED;
while(1);
