NMI implementation issue
I have written the NMI handler for the LPC1768 MCU based target board as below and I am using Keil MDK Lite v4.5. The CPU control enters the NMI handler when invoked by a logic High signal injected to P2.10 but, the issue is upon exit the CPU control loops in the HardFault_Handler implemented in the startup_LPC17xx.s file. Stack memory is set for 100 bytes. Also,is it possible to simulate NMI implementation in Keil MDK v4.5, i have tried it but no success.
void NMI_Handler (void){
LPC_GPIO1->FIOPIN |= (1<<29);
delay();
LPC_GPIO1->FIOPIN &= ~(1<<29);
int main (){
//Configuring GPIO P1.29 as Output to which an LED is interfaced
LPC_PINCON->PINSEL3 &= ~((1<<27)|(1<<26));
LPC_GPIO1->FIODIR |= (1<<29);
//Configuring P2.10 as NMI pin
LPC_PINCON->PINSEL4 &= ~(1<<20);
LPC_PINCON->PINSEL4 |= (1<<21);
//Enable NMI
NVIC_EnableIRQ(NonMaskableInt_IRQn);
while(1);
