64bit arithmetic on Cortex-M0
Hello :)
I am writing a C program that I would like to import to an ARM Cortex-M0.
As new(very new) to the field I have a question that annoys me some days now.
From Generic User Guide of M0 I can see that i can multiply two 32bit numbers but only if they producing a 32 bit result. (so really multiply 16bit numbers but declared as 32 bit?)
infocenter.arm.com/.../index.jsp
1) If I declare something int64_t in my code the compiler will save the value in two 32 bit registers?
2) Isn't 32 bit multiplication providing a 64bit result? It just throws the 32MSBs?
I am asking these cause I would like to do some calculations with 64 bit values and I do not know with what way to continue. (if question 1 is true then the multiplication is done quite easily)
Thank you,
Demetris
