Hi, I am interfacing MCB2140 with HC-SR04 ultrasonic sensor. My code builds without errors. However, i do not get any value in the capture register. How do i test my code without using a LCD? If i need to use a LCD, can anyone provide the code for it?
#include<LPC214x.h> #include<stdio.h> #define PRESCALE 60 void initTimer(void); void delay(int); void initTimer() { T0CTCR = 0x0; //select Timer mode T1CTCR = 0x0; T0PR = PRESCALE -1; // since counter starts from 0 T0TCR = 0x02; //Reset Timer0 T1TCR =0x02; //reset Timer1 T1CCR = 0x0001; //enable CAP0RE for Timer1 } void delay(int us) { T0TCR = 0x02; // reset timer0 T0TCR = 0x01; //Enable timer0 while(T0TC < us) ; //loop for us delay T0TCR = 0x00; //disable Timer0 T0TCR = 0x02; T0TC = 0x00; } void main() { PINSEL0 &= 0xFFCFFFFF; PINSEL0 |= 0x00200000; IO0DIR = 0x00000800; //set P0.11(trigger) as o/p and 10(echo) as i/p IO1DIR = 0x00FF0000;// set P1.16-23 as outputs initTimer(); //// /* initialize the serial interface */ // PINSEL0 = 0x00050000; // Enable RxD1 and TxD1 // U1LCR = 0x83; // 8 bits, no Parity, 1 Stop bit // U1DLL = 97; // 9600 Baud Rate @ 15MHz VPB Clock // U1LCR = 0x03; // DLAB = 0 while(1) { long time,dist, temp; IO1CLR = 0x00FF0000; repeat: IO0SET = 0x00000800; //send high on trigger pin delay(10); //delay for 10us IO0CLR = 0x00000800; // send low after 10us T1TCR = 0x01; //Enable Timer1 if(T1CR0 == 0) { delay(100); } //wait for rising edge to occur on echo pin delay(3); //wait for debounce if(T1CR0 >0) { time = T1CR0; //read value of CR0 reg dist = (time*340)/2; //dist in meters IO1SET = 1<<16; delay(10000); IO1CLR = 1<<16; printf("%d m\n",dist); } else goto repeat; T1TCR = 0x00; //disable Timer1 delay(1000000); } }
Use the Debugger:
http://www.keil.com/support/man/docs/uv4/uv4_debugging.htm
