Hello, I am a student taking Embedded Systems at a university and I am trying to get my code to compile using uVision. I am using a FreeScale FRDM-KL25Z. When I select rebuild or batch build to try to create all my .o files it states:
Build target 'Target 1' ".\Objects\Lab1.axf" - 0 Error(s), 0 Warning(s). Project build/rebuild aborted.
I am trying to compile both .c and .s files inside Source Group 1, and am not receiving any errors when I "translate" them individually. But the linker and/or compiler is not creating my Lab1.axf file. I suspect it has something to do with the build order of my project. I have closed and reopened uVision several times, and tried renaming main.c to Lab1.c to see if that was causing any errors, which was not the case.
Project Details: From the software packs I am using Freescale -> MKL25z128xxx4 In my Source Group 1 I have 3 files, Lab1.c, as.s, and mycap.s. I selected CMSIS CORE 3.40.0 and Device Startup 1.0.0 when I created the project. In debug I am using Pemicro OSJtag/Multilink/Cyclo. In settings for the debugger my interface is OpenSDA using USB1 OpenSDA In Output I have Create HEX File checked, and selected the Objects folder for my objects Everywhere else in Options I have the defaults set (I made sure to go through and click defaults on everything else)
When I click Flash -> Download it says Error: Flash Download failed - Could not load file (which stems from the .axf file not being generated)
If anyone has any ideas of what I need to do to get this program to finish compiling and create the .axf file it would be much appreciated.
