CMSIS ENET : Enable/disable DHCP at run time
I'm developping an ethernet application with LPC4337.
I would like to be able to enable or disable DHCP at run time using CMSIS network library.
There is one function to disable DHCP at run time : dhcp_disable()
works fine.
Then I would like to enable it again. There is no function to do that so I tried to re-initialize network: net_initialize()
This works but if I do the same operation 5 times, net_initialize() hangs.
I guess it's because network ressources are not released and they are allocated each time I call the function but there is no function to release/uninit. ressources.
Does someone have a solution for my application (I really don t want to reset the system each time I want enable the DHCP)?
Thank you.
