Hello, I'm using TM4C123G LaunchPad (EK-TM4C123GXL) to implement a USB CDC Host. I have MDK-Professional but i got this problem when i configure the USB HOST in the "Manage Run-Time Environmnet" The error is: Keil.MDK-Pro::USB:Host require 2.00:CMSIS Driver:USB Host
How can i resolve this problem?
What I meant was select the corresponding CMSIS driver for USB Host.
Check if the USB is connected via SPI or MCI interface and there should be USB Host API in CMSIS Driver section as well.
Hi, USB HOST doesn't exist in CMSIS driver.
Just do what error is asking you to perform.
Select "USB Host" in "CMSIS Driver" Component
