Hi all.. I am trying to interface keypad and Seven Segment display with 89S52. what i need to do is whatever keys are pressed from keypad, it should show on seven segment display. for Eg. if 2 is pressed from keypad then display should show 2. and so on. my code is...
#include<reg51.h> #include<stdio.h> sbit row0=P2^7; //assigning PORT-0 to read rows sbit row1=P2^6; //assigning PORT-0 to read rows sbit row2=P2^5; //assigning PORT-0 to read rows sbit row3=P2^4; //assigning PORT-0 to read rows sfr COL=0xA0; //assigning PORT-2 to read colomns sbit buz=P3^2; sbit seg0=P3^0; sbit seg1=P3^1; sbit seg2=P3^2; sbit seg3=P3^3; sbit seg4=P3^4; sbit seg5=P3^5; void msdelay(unsigned int value); int keypad(); char digi[10]={0x40,0xF9,0x24,0x30,0x19,0x12,0x02,0xF8,0x00,0x10}; unsigned char numbers[6]={"44444"}; void main() { unsigned int i; while(1) { do { numbers[i]=keypad(); i++; } while(i!=6); i=0; { P1=0x40; } } } // MAIN ENDS HERE. void msdelay(unsigned int value) { unsigned int i,j; for(i=0;i<value;i++) for(j=0;j<100;j++); } int keypad() { unsigned char dat[4][4]={'7','8','9','A', // assigning key matrix '4','5','6','B', '1','2','3','-', '*','0','#','+',}; unsigned char colloc,rowloc; COL=0x0F; row0=0; row1=0; row2=0; row3=0; while(1) { do { do { msdelay(90); colloc=COL; colloc&=0x0F; } while(colloc==0x0F); msdelay(90); colloc=COL; colloc&=0x0F; } while(colloc==0x0F); while(1) { row0=0; row1=1; row2=1; row3=1; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=0; break; } row0=1; row1=0; row2=1; row3=1; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=1; break; } row0=1; row1=1; row2=0; row3=1; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=2; break; } row0=1; row1=1; row2=1; row3=0; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=3; break; } } if(colloc==0x0E) return(dat[rowloc][0]); else if(colloc==0x0D) return(dat[rowloc][1]); else if(colloc==0x0B) return(dat[rowloc][2]); else return(dat[rowloc][3]); } }
i have not tried anything because i am not getting any idea of how to start with... because the output from keypad i get is numbers. and to display on seven segment we need hex. how can i do this. in my code, in MAIN function i have just tried to save the numbers from what i get from keypad to array numbers[7]. seven segment display are common anode and are connected to port 1 of 89S52.
