hi to all, i am new in mdk5 and i working on a project that in it i need to communicate through usart of my micro, i want to use from cmsis::usart lib to access usart. when i read the documentation of cmsis i found below example
#include "Driver_USART.h" #include "cmsis_os.h" /* ARM::CMSIS:RTOS:Keil RTX */ #include <stdio.h> #include <string.h> void myUART_Thread(void const *argument); osThreadId tid_myUART_Thread; /* USART Driver */ extern ARM_DRIVER_USART Driver_USART3; void myUSART_callback(uint32_t event) { switch (event) { case ARM_USART_EVENT_RECEIVE_COMPLETE: case ARM_USART_EVENT_TRANSFER_COMPLETE: case ARM_USART_EVENT_SEND_COMPLETE: case ARM_USART_EVENT_TX_COMPLETE: /* Success: Wakeup Thread */ osSignalSet(tid_myUART_Thread, 0x01); break; case ARM_USART_EVENT_RX_TIMEOUT: __breakpoint(0); /* Error: Call debugger or replace with custom error handling */ break; case ARM_USART_EVENT_RX_OVERFLOW: case ARM_USART_EVENT_TX_UNDERFLOW: __breakpoint(0); /* Error: Call debugger or replace with custom error handling */ break; } } /* CMSIS-RTOS Thread - UART command thread */ void myUART_Thread(const void* args) { static ARM_DRIVER_USART * USARTdrv = &Driver_USART3; ARM_DRIVER_VERSION version; ARM_USART_CAPABILITIES drv_capabilities; char cmd; #ifdef DEBUG version = USARTdrv->GetVersion(); if (version.api < 0x200) /* requires at minimum API version 2.00 or higher */ { /* error handling */ return; } drv_capabilities = USARTdrv->GetCapabilities(); if (drv_capabilities.event_tx_complete == 0) { /* error handling */ return; } #endif /*Initialize the USART driver */ USARTdrv->Initialize(myUSART_callback); /*Power up the USART peripheral */ USARTdrv->PowerControl(ARM_POWER_FULL); /*Configure the USART to 4800 Bits/sec */ USARTdrv->Control(ARM_USART_MODE_ASYNCHRONOUS | ARM_USART_DATA_BITS_8 | ARM_USART_PARITY_NONE | ARM_USART_STOP_BITS_1 | ARM_USART_FLOW_CONTROL_NONE, 4800); /* Enable Receiver and Transmitter lines */ USARTdrv->Control (ARM_USART_CONTROL_TX, 1); USARTdrv->Control (ARM_USART_CONTROL_RX, 1); USARTdrv->Send("\nPress Enter to receive a message", 34); osSignalWait(0x01, osWaitForever); while (1) { USARTdrv->Receive(&cmd, 1); /* Get byte from UART */ osSignalWait(0x01, osWaitForever); if (cmd == 13) /* CR, send greeting */ { USARTdrv->Send("\nHello World!", 12); osSignalWait(0x01, osWaitForever); } } }
i am ok with that but i can not undrestand one thing, my micro has 4 usart port, how i can indicate that i want to use for example usart3 of my micor.
A hint might be this line:
Mean that by appending number to name instance of driver we can indicate our purpose uart number??
It means that every UART has has a struct overlaying the registers of the UART.
So Driver_USART3 happens to be a struct overlaying the registers for UART3. And USARTdrv will then be a pointer that points to the registers of UART3 and so will perform all actions on that UART.
got it, thanks ;)
