hi to all i am new in mdk5 and i want create a project with mdk5 and using cmsis::rtx rtos, i wrote a simple blinky program with cmsis::rtx and work well in simulator, but when i deploy it in my board it dose't work in my micro. my micro is lpc1788. can any one tell me how to fix that??, i must done another things or settings to fix that,pls help me. thanks for attention.
Please use the debugger to identify the area of not working. Review the startup code and if it gets stuck in that, or if there is something about your board that the chip needs to understand more better.
my code is as below
/*---------------------------------------------------------------------------- * CMSIS-RTOS 'main' function template *---------------------------------------------------------------------------*/ #define osObjectsPublic // define objects in main module #include <cmsis_os.h> #include "osObjects.h" // RTOS object definitions #include "GLCD.h" //graphic lcd lib #include "Driver_USART.h" //ARM::cmsis::drivers::usart interface #include "uart_setting.h" //setting of uart //defining functions void Usart_Callback(uint32_t event); void Uart_Thread(void const *argunment); extern int Init_Therads(void); void Initial_Uart(void); void init_system(void); //defining interface for usar2 extern ARM_DRIVER_USART Driver_USART2; //defining thereads osThreadId uart_Thread_Id; osThreadDef(Uart_Thread, osPriorityNormal, 1, 0); void Usart_Callback(uint32_t event) { switch(event) { case ARM_USART_EVENT_TX_COMPLETE: osSignalSet(uart_Thread_Id, 0x01); break; case ARM_USART_EVENT_RECEIVE_COMPLETE: break; } } void Uart_Thread(void const *argunment) { /*static ARM_DRIVER_USART * usart_drv = &Driver_USART2; usart_drv->Send("\nUsart Thread startted successfully", 35); osSignalWait(0x01,osWaitForever); usart_drv->Send("\nSending completed", 35);*/ int a = 0; int b = 0; for(;a < 10;a++) { b += 1; } while(1); } extern int Init_Therads(void) { //intilizing thread for controlling uart thread uart_Thread_Id = osThreadCreate(osThread(Uart_Thread), NULL); return 1; } void Initial_Uart(void) { static ARM_DRIVER_USART * usart_drv = &Driver_USART2; usart_drv->Initialize(Usart_Callback); usart_drv->PowerControl(ARM_POWER_FULL); usart_drv->Control(data_Bits | uart_Mode | parity_Bits | stop_Bits | hand_Shaking, uart_Baudrate); usart_drv->Control(ARM_USART_CONTROL_RX, 1); usart_drv->Control(ARM_USART_CONTROL_TX, 1); } void init_system(void) { //initilizing pherphelars SDRAM_32M_16BIT_Init(); GLCD_Init(); lcd_SetBacklight(50); GLCD_Clear(Black); Initial_Uart(); //intialzing therads Init_Therads(); } int main (void) { osKernelInitialize (); // initialize CMSIS-RTOS //initilizing system init_system(); //starting kernel osKernelStart (); // start thread execution }
when i using debuer, after calling init_system function my new thread added successfully to threads in system and thread viwer of mdk5, but after calling osKernelStart, debuger get in to rt_CMSIS file in below line and then it dose not done any thing else
// Thread Service Calls declarations SVC_2_1(svcThreadCreate, osThreadId, const osThreadDef_t *, void *, RET_pointer) SVC_0_1(svcThreadGetId, osThreadId, RET_pointer) SVC_1_1(svcThreadTerminate, osStatus, osThreadId, RET_osStatus) SVC_0_1(svcThreadYield, osStatus, RET_osStatus) SVC_2_1(svcThreadSetPriority, osStatus, osThreadId, osPriority, RET_osStatus) SVC_1_1(svcThreadGetPriority, osPriority, osThreadId, RET_osPriority)
Hi probsaeed sadeghpour,
Is the issue resolved. I too am facing same issue but on GCC ARM compiler. If you have solved the issue, can you post the solution.
Thanks, Satish.
