Hi Everyone,
JTrace Pro is having Ethernet interface and there it said that this interface is used to live stream the trace data.
How can we see this trace data? If debugger use USB interface, then we can see trace data in KEIL TRACE DATA window.
If Ethernet interface is used, any SEGGER tool is needed? No where mentioned about tools to see live streaming trace data.
There is no such problem in ULINKPRO because they directly stream the data through USB only.
If anyone of use the JTrace Pro, please let me know how to use Ethernet interface.
You should be able to see trace information over an ethernet connection, using one of Segger's JLINK Pro drivers.
Have you seen the following page in the JLINK guide? www.keil.com/.../jlink_conf_interface.htm
