Error: L6218E: Undefined symbol
I'm using uVision 5 to develop a firmware, however I can't get the linker to find one of my functions.
When building, I get this error:
Error: L6218E: Undefined symbol three()
I have 3 files, main.c, Test.h, Test.c
main.c :
#include "Test.h"
int main()
{ return three();
Test.h :
#ifndef TEST_H
#define TEST_H
int three();
#endif
Test.c
#include "Test.h"
int three()
{ return 3;
All those files are at the root of my project, I know they get compiled as if I introduce a syntax error in them, compiler reports an error. Also looking at the map file produced, I see that three() was removed:
Removing test.o(i.three), (4 bytes).
For testing purposes, I had --no_remove to linker command line, map file now contains:
0x0002ba76 0x00000004 Code RO 1 i.three test.o
So obviously, the linker is well aware of my function, and will or won't remove it depending on flags.
Regardless, it reports:
.\build\uvision5\test.axf: Error: L6218E: Undefined symbol three() (referred from main.o).
Not enough information to list image symbols.
If I move the content of Test.h/.c to main.c, no problem, so the code is correct.
I suspect a linker configuration or a project configuration issue, but I'm really stuck !
Thanks for your help!
