hello Keil still I donot understand why I should initialize array passed to function inside that function although it is completed in calling function
ex like this part if i make line ExprTokens[TOKEN_NUM-1][TOKEN_LEN-1]=0; then every thing ok and if omitted then program hang in communation part with SD ( sd rx buffer problem)
double ExprEvaluation( char ExprTokens[TOKEN_NUM][TOKEN_LEN],char Tkn) { uint8_t i,j,k; double t0,t1,t2,t3; ExprTokens[TOKEN_NUM-1][TOKEN_LEN-1]=0; // if not exist cause browser hang ...
thanks in advance
You are going to have to debug your own code. Looks like you are looking in the wrong place for the issue.
It is repeated problem I want to know general reasons only learning only if possible to help I will appreciate that very much
It is repeated problem ...
Then you should consider providing a simple example that shows your issue. With PROPER formatting!
