Defining a variable in the bit-band area
I wonder to know is there anyone who define a variable in bit-band area in c programming language for cortex-M3.
I have followed the compiler attribute based on the below link
www.keil.com/.../armcc_chr1359124215827.htm
but when I check the address range, it has been defined out of the scope of bit-banding and it seems the attribute doesn't effect the code even if I use this code __attribute__((at())) ?
As far as I know bit-banded area map each bit into 8 bit if we write 0b00000001 into the 8 bit the corresponding bit become one and vice versa but what I want to know is, it has been said that bit-banded area help us to toggle bit in a atomic way (what I'm looking for) ,how could be accomplished !?
  • Have you looked at the processor-specific header files?
    They show how the individual bits of different peripheral registers are configured.
    By having an int represent a bit directly in the memory controller, the processor does not need to perform a read + modify + write to set or clear a bit. It just writes a value and the memory controller performs the action of setting or clearing the individual bit that is represented by the specified address. So a rather trivial way to adjust the hardware to let a standard programming language magically get "bit" variables.
