I think I have found a bug for ARMCC.
in my case, the correct result which would be:
VCMPE.F32 s0,s1 VMRS APSR_nzcv,FPSCR ITTT LS
But actually, that was:
VCMPE.F32 s0,s1 VMRS APSR_nzcv,FPSCR ITT LS
that was wrong for execute result also, and when i edited the bin file which is compiled and assemblied(change "ITT LS"(0xbf9c) to "ITTT LS"(0xbf9e)), everything looks correctly.
cortex-m4lf (you may see VMPE.F32 and VMRS)
That surely ranks highly in the worst bug reports ever!
What compiler version?
What source code produced the sequence?
What compiler settings were used?
etc. etc. etc
ARMCC 5.6.0.13 in KeilMDK 5.18.0.0
source code likes (but not the same, and i am not sure this will be reproduct that)
#define ARRAY_LENGTH 10 float t0[ARRAY_LENGTH], t1; unsigned char i, arr[ARRAY_LENGTH], count; // do something, assign count, t0, t1, arr; for (i = 0; i < count; i++) { if (arr[i] != 0) // complier has changed these two statement. { if (t0[i] < t1) // complier has changed these two statement. and i donot know how complier make sure t1 is not NaN { continue; } } // do something; }
VCMPE.F32 s0, s1 VMRS APSR_nzcv,FPSCR ITT LS // here should be ITTT LS LDRBLS lr, [r12, #0] CMPLS lr #0 BNE ####### // so this BNE got the wrong flag Z
Compiled by CLR with param "--c99 -c --cpu Cortex-M4.fp -g -O3 -Otime --apcs=interwork --split_sections" (no completely, but I think others are not the key)
Thanks for your prompt reply! i will provide as more info as i can, but except complete source code. even now i cannot confirm is that a bug or just i got the wrong way to use. any way, thank you all again.
there is a mistake, not CLR, just command line.
No point in anyone wasting time looking at it then.
First lesson in hunting a bug: Try to reproduce it.
