i'm doing file explore using fatfs and i declare path string as a char array on top of file explorer file.c problem when i add some code which is not belong to any thing just as test and that code contain any assign variable to variable or when i go to some page in main program an back to explore page the path array crash and file explorer go mad and i become crazy :( please help
Make sure your stack is large enough that it doesn't crash into your heap or statics.
Thanks for reply it was uninitialized item problem it take four days till found
Are you making sure you always build will all compiler warnings enabled?
