I have a STM32F411RE Nucleo board. I can compile and run the 'Blink-LED' program just fine on mbed. I'm trying out 'free version' of uVision 5.13. When I export the 'Blink-LED' program and try to compile it in uVision, I get the following errors:
Build target 'mbed NUCLEO_F411RE' compiling main.cpp... Error: C9511E: Product definition file was not found. The following paths were searched: - C:\Keil_v5\ARM\ARMCC\Bin\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\sw\mappings\mdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:\Keil_v5\ARM\ARMCC\sw\mappings\armcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 1 (build 106) Tool: ArmCC [4d0efa] linking... .\build\Nucleo_blink_led.axf: Error: L9511E: Product definition file was not found. The following paths were searched: - C:\Keil_v5\ARM\ARMCC\Bin\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\..\..\sw\mappings\mdk_cm_pro.elmap - C:\Keil_v5\ARM\ARMCC\Bin\..\sw\mappings\mdk_cm_pro.elmap .\build\Nucleo_blink_led.axf: Error: L9545E: Info key CT.ProductName could not be found in product definition C:\Keil_v5\ARM\ARMCC\sw\mappings\armcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 1 (build 106) Tool: armlink [4d0efa] Finished: 1 information, 0 warning and 2 error messages. ".\build\Nucleo_blink_led.axf" - 2 Error(s), 0 Warning(s). Target not created.
I have the following 'packs' installed: ARM::CMSIS Keil:: MDK-Middleware Keil::STM32F4xx_DFP Keil::STM32NUCLEO_BSP
If someone could point me in the right direction, I'd greatly appreciate it.
Thanks, Duane
Does the mbed export actually support MDK v5 - or does it assume v4?
That would seem to be your key issue...
Well, maybe you have something there. When I go to export a program, the only Keil option is uVision4 NOT uVision5. But, Keil 'seems' to recognize that it is an older project and upgrades it. Maybe that is where the problems start. I sure wish I could get this problem figured out. Other people don't seem to have this issue.
Any suggestions??
Is example hello work or LED blink export into Keil working for any one with STM32F2 M3?
