Hi all,
I use µVision 4.73 evaluation version. My target device is LPC4357 (cortex M4). All works fine, except when I use floating poit math.
volatile float F; #include <math.h> int main(void) { SystemInit(); F = 16.0; F = sqrt(F); }
above is only a snippet of the program. As soon I call the sqrt() I get a HardFault exception. The compiler uses microlib and no FPU is used. (defining F as double or calling sqrtf() same error).
When I enable the FPU, I get the same error before I reach main... stack- and heap size are both 0x4000.
Any idea ?
