About transferring 4-20mA to voltage
Dear friends,
I am working on reading 4-20 mA from Level/pressure/flow transmitters.
I used to use a 10 ohm resistor in series. so I measured the voltage drop on the resistor
but in this circuit I needed the ground from the transmitter device.
Is there a better method not using ground wire from the transmitter?
