Hi, I work on a cc2530 register with keil IDE. I have import the file cc2510.h but i don't understand why rf registers are different with the datasheet.
Moreover these registers are define in XREG. What is this?
#define ADDR XREG( 0xDF05 ) /* Device address #define CHANNR XREG( 0xDF06 ) /* Channel number
Why the register 0xDF06 is not define in the datasheet?
Sorry for my bad english...
Antho
XREG is just another #define somewhere - it might typecast the integer into a void pointer or similar. Just scan the header files and see what XREG does. Or preprocess the source code and look at the output after preprocessor expansion.
the file cc2510.h
Where did you get this file?
Have you contacted the author?
ISTR that ChipCon (now TI) used IAR - so are you trying to use IAR headers with Keil?
This is an 8051 - so, presumably, XREG is mapped into XDATA ... ?
Remember that the 8051 requires a lot of proprietary language extensions to work with 'C' ...
I don't know that product line, but could it be that 10 is just not the same as 30?
