hi, and thanks per advance, I work on Keil uvision5 /cortex-M with ulink pro. all my project are on a network shared drive. all is fine except that all the trace files (*.tdi *.tds ...) are saved in a temporary folder (something like {XXX-YYZ ... }) in the project directory and not in the tmp directory set with the TMP windows environement variable.
this make debuging features are very slow due to network acces to huge file. Is anyone had find a way to set TMP folder in order to set this debugger files in the local TMP folder?
thanks to all.
nicolas.
What about TEMP?
This is why most places use source code management solutions where you checkout code to a local sandbox.
tanks for your answer.
I set TMP and TEMP equal and the result is the same: it's not used.
we use both: source code management with SVN but the local checkout is on a protected network drive to avoid local failure.
"the local checkout is on a protected network drive to avoid local failure"
What is the actual likelihood of a "local failure"?
With frequent check-ins, the impact of a "local failure" is minimised.
How does that compare to the actual time you are wasting because "debuging features are very slow"?
Go figure!
