Hi Community,
I note that Keil Middleware File System Component supports many types of FLASH storage devices (http://www.keil.com/pack/doc/mw/FileSystem/html/fs_operation.html#drive), however the supported devices are external from the MCU itself (USB drive, SD card, external NOR/NAND flash chip connected over SPI or a bus).
Instead, I would like to use the internal (NOR) FLASH of the MCU (in my case, STM32L471). It would require a low-level driver to read/erase/write the internal FLASH. I thought this might be common given large FLASH sizes available, but I did not find much discussion here or elsewhere specifically about internal FLASH file system.
Is there a reason this is not a common approach?
What I'd like is a basic embedded file system (no directory or long file name support, and only a few files) which would permit store/retrieve/update of various length strings and parameters, from some high level API (like f_open(), f_read(), f_write(), etc.) I intended to store parameters in ASCII and use string conversion functions to translate parameters to integer/floating point values etc. with specific reserved character used as delimiter between parameter keys and corresponding values.
I would appreciate to hear some recommendations on good approach for doing this. Do people find a high level interface unnecessary for basic key/value storage and lookup and instead write their own custom interface? Are there examples of good implementations of that online?
Thanks for suggestions!
The block size, erase speed, stalling of the CPU, are all non-conducive.
For configuration/calibration parameters, managing a flash block directly, with a structure, is probably more desirable.
For web server type demos, people of have a tool to create a simple static file system as compilable files. ie take a sub-directory and make a series of C files and inter-related structures to access the data.
github.com/.../makefsdata
Thanks for the comments!
I had not thought about the issues you mention. I can see those issues becoming a problem for increasingly larger files, and also as they are more frequently updated/written.
A data structure mapped to memory and read/write to FLASH as an array of bytes sounds ideal for restore/save a lot of parameters with ease. The only downside I can see is flexibility -- inserting/removing elements wouldn't be possible as the mapping to individual elements (uint32_t, char[], etc.) would change.
