STM32: Viewing flash memory contents
Hello folks,
I wish to view the contents of flash memory on STM32L471 (1MB ROM) MCU using Keil ULINK2 debugger (uVision IDE v5.20.0.0), but when I do so the memory viewer (in Debug mode) displays all 0xFF where I expect to find data. I wonder if someone could suggest what I am doing wrong. Here is some background information.
In my Keil uVision project I have (among other files) a C file gsData.c containing a single initialized array, like this:
uint16_t gs[] = {
   38,   // 0x0026
  217,   // 0x00d9
   72,   // 0x0048
    0,   // 0x0000
    4,   // 0x0004
I use a modified scatter file to divide the flash ROM into a few regions so I can place gsData.o at a specific memory address. I do this because the array gs[] contains data which needs period updating without changing the main program. My scatter file looks like this:
LR_IROM1 0x08000000 0x00100000  {   ; load region size_region
  ER_IROM1 0x08000000 0x00060000 {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  ER_IROM2 0x08060000 0x00004000 {
    gsData.o (+RO)                  ; array gs[] will be located at 0x08060000
I verified from the MAP file that gs[] is placed at the location I expect:
    Global Symbols
    Symbol Name                              Value     Ov Type        Size  Object(Section)
    gs                                       0x08060000   Data        1576  gsData.o(.constdata)
    Execution Region ER_IROM2 (Base: 0x08060000, Size: 0x00000628, Max: 0x00004000, ABSOLUTE)
    Base Addr    Size         Type   Attr      Idx    E Section Name        Object
    0x08060000   0x00000628   Data   RO        4583     .constdata          gsData.o
Now I compile and download my program to the MCU and enter debug mode in uVision IDE. I press "F5" to run the program to make sure the debugger is connected to the target and in the "Memory 1" window I enter the address 0x08060000 (alternatively the name of the symbol "gs" also works). I find the memory window shows all uninitialized flash at the address I expect to find gs[].
0x08064000: FF FF FF FF FF ...
I don't understand why I am not seeing the contents of the initialized array gs[] as defined in the C file.
Can anyone see what I am doing wrong here?
Thank you!
