ASSEMBLY PROGRAMMING
How to do ASSEMBLY programming in KEIL Uvision 5?!
for that which board i have to select in Target Options?!
  • The same way you do it in any other toolchain:
    1. Write the code - using the editor;
    2. Build the code;
    3. Download & run/debug the code.
    All the Keil documentation is here: http://www.keil.com/support/man/
    Note that each architecture has its own specific assembler - so, beyond the above, this really isn't a "Non-Specific (General)" question.
    "which board i have to select in Target Options?!"
    The hardware neither knows nor cares what you write your source code in - whether it's assembler, or C, or whatever.
    Therefore, it makes no difference to the board selection whether you write your source code in assembler, or C, or whatever
    2. Build the code;
