read messages uisng 89E516RD2
hi all,
i need a small help from you all...
i am trying to interface GSM module with 89E516RD2 microcontroller. and receive messages and display the content of message to the LCD.. i have written a basic code to test it.... but the things are not working proper...
can anybody please let me know where the mistake is...
#include<P89V51Rx2.h>
sbit LCD_en=P0^1;
sbit LCD_rs=P0^0;
#define LCD_DELAY 800 /* Delay for 1 ms */
#define lcdclear() LCD_command(0x1)        /* Clear display LCD */
#define LCD_origin() LCD_command(0x2)      /* Set to origin LCD */
#define lcdrow1() LCD_command(0x80)        /* Begin at Line 1 */
#define lcdrow2() LCD_command(0xC0)        /* Begin at Line 2 */
#define lcdrow3() LCD_command(0x94)        /* Begin at Line 3 */
#define lcdrow4() LCD_command(0xD4)        /* Begin at Line 4 */
#define Shiftcursorleft() LDC_command(0x04)
void LCD_delay(unsigned char ms);
void LCD_enable();
void LCD_command(unsigned char command);
void LCD_putc(unsigned char ascii);
void LCD_puts(unsigned char *lcd_string);
void LCD_init();
void uartinit();
void cmd(unsigned char cd);
void lcd_datawrt(unsigned char *msg);
unsigned char getdat(void);
void dat(unsigned char dt);
void delay (unsigned int t);
void main()
unsigned char i,msg[50];
uartinit();
LCD_init();
while(1)
lcdrow1();
LCD_puts("WAITING FOR MSG");//wait
while((getdat())!=':');
while((getdat())!='+');
while(getdat()!='\n');
for(i=0;i<20;i++)
msg[i]=getdat();
if(msg[i]=='\r')
break;
msg[i]='\0';
lcdrow1();
LCD_puts(msg);//wait
void uartinit(void)     //uart initialising
TMOD=0x20;
TH1=0x0FD;//9600 baud rate
SCON=0x50;
TR1=1;
unsigned char getdat(void)      //receive gps data serially
unsigned char a;
while(RI==0);
a=SBUF;
RI=0;
return(a);
      unsigned char n;
      unsigned int i;
      for (n=0; n<ms; n++)
              for (i=0; i<LCD_DELAY; i++); /* For 1 ms */
void LCD_enable()
    LCD_en = 0; /* Clear bit P2.4 */
    LCD_delay(1);
    LCD_en = 1; /* Set bit P2.4 */
    LCD_rs = 0; /* Clear bit P2.5 */
    P1 = (P1 & 0xF0)|((command>>4) & 0x0F);
    LCD_enable();
    P1 = (P1 & 0xF0)|(command & 0x0F);
    LCD_enable();
    LCD_delay(1);
    LCD_rs = 1; /* Set bit P2.5 */
    P1 = (P1 & 0xF0)|((ascii>>4) & 0x0F);
    LCD_enable();
    P1 = (P1 & 0xF0)|(ascii & 0x0F);
    LCD_enable();
    LCD_delay(1);
      while (*lcd_string)
              LCD_putc(*lcd_string++);
void LCD_init()
    LCD_en=1;       /* Set bit P2.4 */
    LCD_rs=0;           /* Clear bit P2.5 */
    LCD_command(0x33);
    LCD_command(0x32);
    LCD_command(0x28);
    LCD_command(0x0C);
    LCD_command(0x06);
    LCD_command(0x01); /* Clear */
    LCD_delay(256);
  • >>but the things are not working proper...
    What does that mean? What aspects of what is it supposed to do does it achieve? Break the thing down into simple steps, where you can test each step is working as expected. Do not try to build a complex system/interactions until you have proven you've got basic functionality. Start perhaps by getting the serial port working, and then the display, that way you can confirm or output diagnostic information.
