In C program,I had wroten a declaration like this: __global_reg(4) int Reg_R7; I wish r7 register be reserved,but it dose not work: r7 register still be used by compiler in orther work. How can I do? Thank a lot!
You must be a very smart guy if you have found a real requirement for this feature.
But I wonder: Are you smart enough to have looked at the Caution section of www.keil.com/.../armcc_chr1359124967427.htm ?
There is only one .c file in my project. The program after the delaration be compiled that r7 register involved. I had read the web page you noticed me carefully, but I have no idear. Would you please tell me what shoud I do. Thank you!
"Would you please tell me what shoud I do."
What you should have started with, was to give a very good and convincing reason why you want to steal one register from the compiler and make it into a global variable - is your program so special that this actually gains you any advantage?
