I am new to USB HID protocol.
I am using LPC2368 to implement HID protocol.
My requirement is to send data to host at given time interval and to accept some response from host/PC which is independent of the data being sent by device to host. For this have done implementation using interrupt pipes: IN Pipe (End Point number 1) ---> To send data to Host/PC. OUT Pipe (End Point number 4) ---> To receive data from Host/PC.
When I test these pipes individually, they work absolutely OK.
But when implemented together following problems /observations are seen: 1. IN Pipe works fine initially. But wen something is sent on OUT pipe(by Host) it is received via Control Pipe (Pipe 0). 2.At this instance IN Pipe stops working.
Can someone please let me know : 1. Is there something wrong with implementation logic? 2. Cant we have IN interrupt Pipe and OUT interrupt Pipe initialized in one application?
Looking forward for reply.
Thanks, Sonam.
It suggests - You are working on Windows. - The OUT endpoint is not established on your config descriptor set. When a HID device doesn't have interrupt OUT endpoint, the OS redirects WriteFile call to control transfer.
OR
- You are working on the in-box HID driver (instead of libusb) on Linux Linux default HID driver doesn't send to interrupt OUT endpoint.
Which one is your case?
Tsuneo
Hello Tsuneo,
Thanks for your reply. I am using Windows Host system. I have shared below the Description Settings done at controller. Please have a look at it.
const BYTE USB_DeviceDescriptor[] = { USB_DEVICE_DESC_SIZE, /* bLength */ USB_DEVICE_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0110), /* 1.10 */ /* bcdUSB */ 0x00, /* bDeviceClass */ 0x00, /* bDeviceSubClass */ 0x00, /* bDeviceProtocol */ 64, /* bMaxPacketSize0 */ WBVAL(0x4587), /* idVendor */ WBVAL(0x1212), /* idProduct */ WBVAL(0x0100), /* 1.00 */ /* bcdDevice */ 0x11, /* iManufacturer */ 0x88, /* iProduct */ 0x96, /* iSerialNumber */ 0x01 /* bNumConfigurations */ Tried changing this to 3(sinice there are 3 pipes but didnt help, please comment on this }; const BYTE USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bDescriptorType */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL( /* wTotalLength */ USB_CONFIGUARTION_DESC_SIZE + USB_INTERFACE_DESC_SIZE + HID_DESC_SIZE + USB_ENDPOINT_DESC_SIZE ), 0x01, /* bNumInterfaces */ 0x01, /* bConfigurationValue */ 0x00, /* iConfiguration */ USB_CONFIG_BUS_POWERED /*|*/ /* bmAttributes */ /*USB_CONFIG_REMOTE_WAKEUP*/, USB_CONFIG_POWER_MA(100), /* bMaxPower */ /* Interface 0, Alternate Setting 0, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x01, /* bNumEndpoints */ USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x5C, /* iInterface */ /* Interface 1, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x01, /* bInterfaceNumber */ 0x01, /* bAlternateSetting */ 0x01, /* bNumEndpoints */ USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x5C, /* iInterface */ /* Interface 4, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x04, /* bInterfaceNumber */ 0x01, /* bAlternateSetting */ 0x01, /* bNumEndpoints */ USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x5C, /* HID Class Descriptor */ HID_DESC_SIZE, /* bLength */ HID_HID_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0100), /* 1.00 */ /* bcdHID */ 0x00, /* bCountryCode */ 0x01, /* bNumDescriptors */ HID_REPORT_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(HID_REPORT_DESC_SIZE), /* wDescriptorLength */ /* Endpoint1, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize = 64*/ 0x01, /* bInterval = 1ms*/ /* Terminator */ 0 , /* bLength */ /* Endpoint2, HID Interrupt Out */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(4), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0001), /* wMaxPacketSize = 1 */ 0x0A, /* bInterval */=10ms /* Terminator */ 0 /* bLength */ };
Looking forward to hear from you.
-- Regards, Sonam
To add an interrupt OUT EP to a HID descriptors, - Append the interrupt OUT EP descriptor, at the end of the config descriptor set (before the terminating "0") - Increase the config: wTotalLength by the size of EP descriptor - Increase the interface: bNumEndpoints by one for the OUT EP - Also, merge the report descriptors.
Here is revised version of your config set.
const BYTE USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bDescriptorType */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL( /* wTotalLength */ USB_CONFIGUARTION_DESC_SIZE + USB_INTERFACE_DESC_SIZE + HID_DESC_SIZE + USB_ENDPOINT_DESC_SIZE + USB_ENDPOINT_DESC_SIZE // <---------- for OUT EP ), 0x01, /* bNumInterfaces */ 0x01, /* bConfigurationValue */ 0x00, /* iConfiguration */ USB_CONFIG_BUS_POWERED /*|*/ /* bmAttributes */ /*USB_CONFIG_REMOTE_WAKEUP*/, USB_CONFIG_POWER_MA(100), /* bMaxPower */ /* Interface 0, Alternate Setting 0, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x02, /* bNumEndpoints */ // <-- for OUT EP USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x5C, /* iInterface */ /* HID Class Descriptor */ HID_DESC_SIZE, /* bLength */ HID_HID_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0111), /* 1.11 */ /* bcdHID */ // 1.00 --> 1.11 0x00, /* bCountryCode */ 0x01, /* bNumDescriptors */ HID_REPORT_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(HID_REPORT_DESC_SIZE), /* wDescriptorLength */ /* Endpoint1, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize = 64*/ 0x01, /* bInterval = 1ms*/ /* Terminator */ 0 , /* bLength */ /* Endpoint2, HID Interrupt Out */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(4), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0001), /* wMaxPacketSize = 1 */ 0x0A, /* bInterval */=10ms /* Terminator */ 0 /* bLength */ };
Post your report descriptor, too.
Oops, the terminator "0" was still there.
const BYTE USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bDescriptorType */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL( /* wTotalLength */ USB_CONFIGUARTION_DESC_SIZE + USB_INTERFACE_DESC_SIZE + HID_DESC_SIZE + USB_ENDPOINT_DESC_SIZE + USB_ENDPOINT_DESC_SIZE // <---------- for OUT EP ), 0x01, /* bNumInterfaces */ 0x01, /* bConfigurationValue */ 0x00, /* iConfiguration */ USB_CONFIG_BUS_POWERED /*|*/ /* bmAttributes */ /*USB_CONFIG_REMOTE_WAKEUP*/, USB_CONFIG_POWER_MA(100), /* bMaxPower */ /* Interface 0, Alternate Setting 0, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x02, /* bNumEndpoints */ // <-- for OUT EP USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x5C, /* iInterface */ /* HID Class Descriptor */ HID_DESC_SIZE, /* bLength */ HID_HID_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0111), /* 1.11 */ /* bcdHID */ // 1.00 --> 1.11 0x00, /* bCountryCode */ 0x01, /* bNumDescriptors */ HID_REPORT_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(HID_REPORT_DESC_SIZE), /* wDescriptorLength */ /* Endpoint1, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize = 64*/ 0x01, /* bInterval = 1ms*/ /* Endpoint2, HID Interrupt Out */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(4), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0001), /* wMaxPacketSize = 1 */ 0x0A, /* bInterval */=10ms /* Terminator */ 0 /* bLength */ };
Hi Tsuneo,
It worked by changing no. of end point configurations and removing extra terminator at the end of end point descriptor.
Thanks for your guidance!
-- Regards, Sonam.
