I have made a code where all the gloabl/static variables are declared like given an example below.
uint8_t x; uint8_t y;
void main() { x = 0; y = 0; }
None of global/static variables is defines as: uint8_t x = 5;
Abovee is just example, I have many variables are defined. All are assigned values on entering into main, none before that.
So all variables should go to bss section. But code build shows R/W section. It should be zero but it is not. Below is one example for same code:
1. Opt setting : No corss module, no microlib , level 0 code: 13774 RO data: 426 RW data: 68 ZI data: 19108
1. Opt setting : cross module, no microlib , level 3, optimize for time code: 7590 RO data: 426 RW data: 48 ZI data: 19104
In both setting there is R/W data even it should not be there. Why is that so
