CMSIS Driver v1.10 UART_STM32F4xx.c Bug
CMSIS Driver UART Revision: V1.02
file C:\Keil\ARM\Pack\Keil\STM32F4xx_DFP\1.0.8\RTE_Driver\UART_STM32F4xx
function UART_ReadData
static int32_t UART_ReadData (uint8_t         *data,
                              uint32_t         size,
                              UART_RESOURCES  *ptr_uart) {
  volatile uint32_t val;
  osMutexWait(ptr_uart->info->mutex_read, osWaitForever);
  if ((size == 0) || (ptr_uart->info->rx.empty == true)) {
    osMutexRelease(ptr_uart->info->mutex_read);
    return 0;
  val = (ptr_uart->info->rx.idx_in - ptr_uart->info->rx.idx_out) & (ptr_uart->rx_buffer_size - 1);
  if (val == 0) val = ptr_uart->rx_buffer_size;
  if (size > val) size = val;
  if ((ptr_uart->hw_flow == true) && (ptr_uart->manual_rts_cts == false)) {
    if (ptr_uart->flow_ctrl_threshold < val)
      GPIO_PinWrite(ptr_uart->pin_rts.port, ptr_uart->pin_rts.num, 0);
  if (size > (ptr_uart->rx_buffer_size - ptr_uart->info->rx.idx_out)) {
    memcpy(data, ptr_uart->rx_buffer + ptr_uart->info->rx.idx_out, val);
    memcpy(data + val, ptr_uart->rx_buffer, size - val);
    if (ptr_uart->info->rx.idx_in == (size - val))
      ptr_uart->info->rx.empty = true;
    ptr_uart->info->rx.idx_out = size - val;
  } else {
    memcpy(data, ptr_uart->rx_buffer + ptr_uart->info->rx.idx_out, size);
    val = (ptr_uart->info->rx.idx_out + size) & (ptr_uart->rx_buffer_size - 1);
    if (ptr_uart->info->rx.idx_in == val)
    ptr_uart->info->rx.idx_out = val;
Guess what will be if variable size is less than val?
