Hello, I'm trying to explore the new MDK 5.11, I started with MCB1800 Board and FTP Server Example but I can't use SD Card, the demo fails to mount file system.
I tried also on a custom board with different PHY (SMSC 8710A) the ethernet part works fine but SD Card still not working.
With the previous MDK 4.73 the board MCB1800 with FTP Server works fine. Can someone help me?
Many Thanks Stefano Bianconi
FTP server works fine on my MCB1800. Did you try to debug your code? Did you check finit or fmount return codes?
I have MCB1800 V1.2, LPC1800_DFP V2.1.0 and my Middleware is V6.0.0.
