Sd card corruption MDK-ARM 5.12
I can't post messages to http://www.keil.com/forum/60400/ hence this new thread.
We did stress-test the file system quite a bit and are unable to see the problems you are reporting. Are you using the latest middleware releases? Can you provide us more information?
Note: this is not a support forum but a user forum.
In case that you have problems with our products, report the issue as described under http://www.keil.com/support.
