my c code is as shown below but when i compile in keil compailer it will show as c(4): warning C318: can't open file 'DELAY.H' c(21): warning C206: 'delay_ms': missing function-prototype (21): error C267: 'delay_ms': requires ANSI-style prototype Target not created please someone help me to correct this
#include<stdio.h> #include<math.h> #include<reg51.h> #include"DELAY.H" # define DATA P1 void msdelay(unsigned int); sbit e=P3^7; sbit rw=P3^6; sbit rs=P3^5; sbit s1=P2^0; sbit s2=P2^1; sbit s3=P2^2; sbit relay=P0^6; sbit s4=P2^3; void mov_stepper(unsigned char dir,unsigned char rot) { while(rot>0) { if(dir=='c') { P0=0X08; delay_ms(5); P0=0X04; ms_delay(5); P0=0X02; ms_delay(5); P0=0X01; ms_delay(5); } if(dir=='a') { P0=0X01; ms_delay(5); P0=0X02; ms_delay(5); P0=0X04; ms_delay(5); P0=0X08; ms_delay(5); } rot--; } } void lcd_cmd(unsigned char temp) { DATA=temp; rs=0; rw=0; e=1; ms_delay(5); e=0; ms_delay(5); } void lcd_data(unsigned char temp) { DATA=temp; rs=1; rw=0; e=1; ms_delay(5); e=0; ms_delay(5); } void lcd_init() { lcd_cmd(0x38); lcd_cmd(0x06); lcd_cmd(0x0e); lcd_cmd(0x01); lcd_cmd(0x80); } void lcd_puts(unsigned char *s) { lcd_init(); while(*s!='\0') { lcd_data(*s); s++; } } void main() { P0=0X00; P2=0X00; while(1) { if(s1==1) { mov_stepper('c',3); lcd_puts("FIELD A"); while(s1!=0) { relay=1; } relay=0; mov_stepper('a',3); lcd_puts("MONITORING"); } if(s2==1) { mov_stepper('c',6); lcd_puts("FIELD B"); while(s2!=0) { relay=1; } relay=0; mov_stepper('a',6); lcd_puts("MONITORING"); } if(s3==1) { mov_stepper('a',9); lcd_puts("FIELD C"); while(s3!=0) { relay=1; } relay=0; mov_stepper('c',9); lcd_puts("MONITORING"); } if(s4==1) { lcd_puts("FIELD D"); while(s4!=0) { relay=1; } relay=0; lcd_puts("MONITORING"); } lcd_puts("MONITORING"); } }
follow the posting instructions and, maybe someone can figure out your problem
anyhow based on the errors I doubt it is "my c code", the errors are typical for a download from the web
Rule #1 when you get compilation errors: Try to understand the first error you get.
"c(4): warning C318: can't open file 'DELAY.H'"
So - why should _we_ try to help you with this? If this is _your_ code, then _you_ already have written a "delay.h" file.
If this is _not_ your code, then maybe you should look for a "delay.h" file in the same location you found all the other code.
You need to improve your C skills a bit more before you try to sit down and take the next test at school - your teacher really expect you to understand the meaning of include files. And the result of trying to include a file that the compiler can't locate...
I got the same code. You can fix it to make a file "DELAY.H" and put in the line
void msdelay ( unsigned int tadger ) { if ( tadger != 0 ) msdelay ( tadger-- ); }
And that would be a high score in bad content of the file.
Why place the implementation in the header file, when the original code was written with the intention of having the delay in a separate source file?
Secondly - the OP has significant issues with what name to use for the delay function. And you selected to suggest a third alternative name.
Thirdly - why implement a recursive delay?
