I'm using RTX on the new XMC devices and I discovered a problem with sending over UART.
The KEIL UART driver defines the TX IRQ in uart.c as
#if (RTE_UART0 != 0) #if (UC_SERIES == XMC14) void IRQ9_Handler() { UART_IRQHandler (uart[0],USIC0_0_IRQn ); } void IRQ10_Handler() { UART_IRQHandler (uart[0],USIC0_1_IRQn); } #else void USIC0_0_Handler() { UART_IRQHandler (uart[0],USIC0_0_IRQn ); } void USIC0_1_Handler() { UART_IRQHandler (uart[0],USIC0_1_IRQn); } #endif #endif
But in the xmc4800.h and startup_xmc4800.s file (from the pack) the IRQ handlers are named different:
#define IRQ_Hdlr_84 USIC0_0_IRQHandler EXPORT USIC0_0_IRQHandler [WEAK]
This leads to an unhandled IRQ exception.
Is this a bug in the pack's files or what am I doing wrong? Should the xmc4800.h file be modified by µVision after I have configured the UART? Of course I can disable the write protection of xmc4800.h and add the correct IRQ handler, but that's not the best way in my opinion.
Any help is appreciated.
Michael
