Issue while jumping to an image in non default location
Am working on ATMEL Sam4cms based board and trying to write a basic application (lets say bootloader) which will jump to an image placed in a different location.
Here is my scatter file for bootloader which starts at 0x1000000
; *** Scatter-Loading Description File generated by uVision ***
; load region
BOOTLOADER_IROM1 0x1000000 0x100000
{ ; Execution Region ER_IROM1 0x1000000 0xFFF0 { *.o(RESET, +First) *(InRoot$$Sections) * (.init_array) .ANY (+RO) }
; RW data RW_IRAM0 0x20000000 0x00002000 { .ANY (+RW +ZI) *(HEAP) }
RW_IRAM1 0x2003F000 UNINIT 0x00001000{ ; ZI data will not be initialized to zero *(NoInit) }
And for App which starts at 0x01010000
APP_IROM1 0x1010000 NOCOMPRESS 0xF0000 { ; load region size_region ER_IROM1 0x1010000 0xF0000 { ; load address = execution address *.o(RESET, +First) *(InRoot$$Sections) * (.init_array) .ANY (+RO) }
RW_IRAM0 0x20002000 0x0003D000 { .ANY (+RW +ZI) *(HEAP) }
and the code to jump
int main()
{ __disable_irq();
std::uint32_t i = 0;
// Disable IRQs
for (i = 0; i < 8; i ++) NVIC->ICER[i] = 0xFFFFFFFF;
// Clear pending IRQs
for (i = 0; i < 8; i ++) NVIC->ICPR[i] = 0xFFFFFFFF;
// -- Modify vector table location
// Barriars
__DSB();
__ISB();
_binExec(reinterpret_cast<void *>(0x1010000 ));
__asm__ void _binExec (void * l_code_addr)
{ mov r1, r0 ldr r0, [r1, #4] ldr sp, [r1] /*msr msp, [r1]*/ blx r0
Though the value shown at r0 is inline with map file's Reset_Handler, program counter doesnot jump to that address, it simply hangs.
Getting "No Synchronisation" as keil trace error.
Can anyone please help.
Regards
Prasad
