Hi, I was trying to configure PLL and other clocks for LPC2378.While setting the processor clock to 72 MHz(Max CCLK as per the User manual), the code stuck's.The code goes like this, after setting System Controls and Status register(init_SCSRegister() function) it goes for the init_PLL_CLOCKS() function. The code get's suck at CCLKCFG=0x03, as iam using 12 Mhz external crystal and PLL configured to 288Mhx expected CCLK = 288/4 = 72Mhz. For other Lower CCLk's(Like 48 Mhz(CCLKCFG=0x05)) its working fine .
Hardware Details
Custom Board Controller- LPC2378 Revision D External Osc - 12Mhz IDE Keil micro vision 3
void init_SCSRegister(void){ SCS|=(BASE_VALUE<<GPIOM); // Setting the GPIOM Bit SCS&=~(BASE_VALUE<<MCIPWR); SCS&=~(BASE_VALUE<<OSCRANGE); // Clearing the Osc range bit(External Crystal 12Mhz) SCS|=(BASE_VALUE<<OSCEN); // Enabling External Oscillator while(!(SCS&(BASE_VALUE<<OSCSTAT))); // Waiting for the Oscillator to stabilize } void init_PLL_CLOCKS(void){ if(PLLSTAT&(BASE_VALUE<<PLLC_Status)){ PLLCON&=~(0x01<<PLLC);// Disconnect PLL if already connected feed_PLL(); // PLL Feed Sequence } PLLCON=0x00; // Disable PLL feed_PLL(); // PLL Feed Sequence CLKSRCSEL=0x01; // Selects the main oscillator as the PLL clock source. PLLCFG = ((1<<NSEL)|(47<<MSEL));// Switching PLL to 288MHz(12Mhz x 48 /2 ) feed_PLL(); // PLL Feed Sequence PLLCON=0x01; // Enable PLL feed_PLL(); // PLL Feed Sequence CCLKCFG=0x03 ; // Setting processor clock(CCLK) to 72 Mhz(288/4) USBCLKCFG=0x05; // Setting USB clock to 48Mhz(288/6) PCLKSEL0=0; // Setting to default clock divider for peripheral(CCLK/4) PCLKSEL1=0; // Setting to default clock divider for peripheral(CCLK/4) while( !( PLLSTAT & (BASE_VALUE<<PLOCK_Status))); //Wait until PLL get's locked PLLCON|=(0x01<<PLLC); //Connect PLL feed_PLL(); // PLL Feed Sequence } void feed_PLL(void){ PLLFEED = 0xAA; PLLFEED = 0x55; }
Will it be due to error/Tolerance with external crystal?? or doesn't this chip/version cant be switched to 72Mhz CCLK??
Please add your comments.
Thank You
Are you really sure about your values?
Remember that the formula is FCCO = (2 × M × FIN) / N
For 72MHz with 288MHz PLL you should have M = 12, N = 1 M = 24, N = 2 M = 36, N = 3 M = 48, N = 4 ... M = 384, N = 32
With M = 48 an N = 2 you get a FCCO speed of 576 MHz.
Hi Westermark,
Sorry sir, That was a mistake from my side. Yes it is like as you said FCCO = (2 × M × FIN) / N , I missed the multiplication factor 2 so i was trying to switch CClk to 144Mhz which made the code hang.Corrected the code .Thanks a lot for the help.
Regards Sreekanth MK
Sounds like you might have managed to run your processor overclocked to 96MHz earlier :)
Yes :) :) :)
