Hi there
I'm new to the uVision environment and having some trouble with it. I hope someone can help. I'm working with a FX2 USB chip from Cypress and have downloaded a sample project from Cypress for uVision. I startet working with uVision 2 firstly but decided to upgrade to uVision 5 and buyed the compiler C51.
Compiling the sample project is done without any errors. But if I add an existing C file to the project, uVision does not find the header files which are included in this specific C file. Even adding the include paths to the project options does not help. The header files are located in the same folder as the C file is located. The funny thing is: some of the C files from the sample project uses the same header files as it is used in the C file I just added. But there is no problem in finding them.
Is there a way to tell uVision where to find this header files? What am I doing wrong?
Does the C file include the headers using <> or "" around the name?
If using "", then you would normally not need to do anything since the compiler would expect to start looking relative to the directory of the C file. If <> then the compiler will care about system directories.
But there can always be a bit of special "bonus" functionality around the use of header files and I don't use C51 so I'm not sure if "" includes will also make use of system include directories, or the exact order of directories tested.
The C file uses "" around the name to include the header file. Since other C files also use some of the same header files and are located in the same ./Source folder, there should be no problem with including them. I think this is a linker problem oder some kind of project setup problem.
The linker isn't involved in any use of header files.
Have you been editing the compilation options for this specific C file, or are all options specified on the project level?
Can you manage to produce a traditional Makefile, so you can visually see if there would be any difference in compiler options when processing this specific C file?
I've tried both: First I made the compilations options on project level. But I also tried to make the options for the specific C file. None of them worked.
As far as I know, uVision is not able to generate make files. I only have the option to generate a map file, but you don't see any information about the copiler settings for the C files in the project
These links might be relevant when looking for build differences between the different source files: http://www.keil.com/support/docs/868.htm http://www.keil.com/support/docs/2594.htm
I just discovered a new effect: I have removed the C file from the project and also deleted the C file in the source folder. My idea was to create the file from scratch, to resolve the problem with the included header files. But now, when I reopen the uVision project, add a new C file and name it exactly the same as it was named before, uVision automatically includes the header files in the project view. But there is not a single line written in the new C file. Is this a bug in uVision?
When building the source file, uVision detects include files and can - depending on configuration - show these include files in the project tree as childs to the individual C files.
But when you build, Keil should be able to update these dependencies to match the actual include files used.
