header and object files missing
Hi there
I'm new to the uVision environment and having some trouble with it. I hope someone can help.
I'm working with a FX2 USB chip from Cypress and have downloaded a sample project from Cypress for uVision. I startet working with uVision 2 firstly but decided to upgrade to uVision 5 and buyed the compiler C51.
Compiling the sample project is done without any errors. But if I add an existing C file to the project, uVision does not find the header files which are included in this specific C file. Even adding the include paths to the project options does not help. The header files are located in the same folder as the C file is located.
The funny thing is: some of the C files from the sample project uses the same header files as it is used in the C file I just added. But there is no problem in finding them.
Is there a way to tell uVision where to find this header files? What am I doing wrong?
  • Does the C file include the headers using <> or "" around the name?
    If using "", then you would normally not need to do anything since the compiler would expect to start looking relative to the directory of the C file. If <> then the compiler will care about system directories.
    But there can always be a bit of special "bonus" functionality around the use of header files and I don't use C51 so I'm not sure if "" includes will also make use of system include directories, or the exact order of directories tested.
