I created a bootloader with the default flash start address A (0x08000000) which flashes an application on address B (0x0802000) and then runs this application. This all works fine. Now I want to start the debugger on address B. Using the linker options I can make uVision debugger flashing the application on address B but the debugger seems not to start the application.
What setting do I need to make the debugger start at address B?
Henk
Use an ini script that assigns PC.
