Can debug ini file change IDE settings?
Hello all,
I would like to ask you for help with following problem. I have a working debug ini file for a microcontroller based on ARM Cortex-M3 core.
I want to use serial wire trace (SWO) feature. For this purpose the "Trace Enable" option has to be checked in debugger settings. Is there a debug command allowing to do this automatically or it has to be checked manually each time?
Thank you in advance for help.
Best regards,
Jaroslav
