How to process OUT Vendor Request with data stage
Hello, dear experts.
I have a problem with the USB component ver 6.5 of MDK-Professional Middleware.
I'm developing vendor specific device and I use USB0 of the microcontroller LPC4337JBD144. I use USB component ver 6.5.
After sending OUT Vendor Request with data stage it's impossible to process any IN Vendor Request. It looks as if it's processed successfully in my firmware program (it continues to work), but my PC application just freezes and waits for a response of a driver untill I detach my device or reset it using debugger.
I added a file "USBD_User_Device_0.c" to my project and modified it in order to process Vendor specific Requests. I changed a callback function the next way
usbdRequestStatus USBD_Device0_Endpoint0_SetupPacketReceived (const USB_SETUP_PACKET *setup_packet, uint8_t **buf, int32_t *len)
  switch (setup_packet->bmRequestType.Type) {
    case USB_REQUEST_VENDOR:
      switch (setup_packet->bmRequestType.Recipient){
        case USB_REQUEST_TO_DEVICE:
          switch (setup_packet->bRequest){
            ... // some code
            case USB_VEND_REQ_LONG_COMM:   // bRequest = 4
              CommStruct.CommLength = setup_packet->wLength;
              CommStruct.RespLength = setup_packet->wIndex;
              // When I call this function, the problem appears. Without calling it everything works properly
              usbReadStat = USBD_EndpointRead(0,       USB_ENDPOINT_OUT(0), CommStruct.CommBuff, 64/*CommStruct.CommLength*/);
              // Here you can see that I tried different ways to solve the problem. I waited, aborted transition, but nothing helped me.
              //while (USBD_EndpointReadGetResult(0, 0x00) != CommStruct.CommLength);
              //USBD_EndpointAbort(0, USB_ENDPOINT_OUT(0));
              ... // some code
              break;
      break;
I have to add, that OUT Vendor Requests without data stage are processed successfully even after OUT Vendor Requests with data stage.
I use the toolchain MDK-ARM Professional version 5.14.0.0 and Windows 7 64-bit.
Thank you for any help.
