Timer1 and External Memory Issue LPC2478
I am trying to use both timer1 and the microcontroller's external memory on this board. The code I'm currently testing with is below. The problem is that when the external memory is enabled in the makefile, it seems to either disable or interfere with timer1.
With extmem disabled, the PWM output (connected to a motor in this case) works correctly and turns on and off as set by timer1. However enabling extmem in the makefile causes the motor to remain on constantly, seemingly ignoring timer1.
Does the extmem disable or interfere with timer1? Is there another problem or some settings missing?
#include <lpc24xx.h>
int main(void)
        unsigned int motor_status = 0;
        T1TCR = 0x02; //Timer Reset
        T1IR |= 1; //Clear Interrupt Register
        T1MR0 = 1200000; //Match Value 1 sec
        T1MCR |= 3; //Reset Counter and Set Interrupt on Match
        T1TCR = 0x01; //Start timer
        PINSEL2 |= (3<<6); //Set (P1.3) PWM Pin Configuration
        PWM0PCR |= (1<<10); //PWM Set To PWM0[2]
        PWM0MR0 = 120000; //PWM Frequency
        PWM0MCR |= (1<<1); //Reset Count On Match
        PWM0MR2 = 120000; //PWM Pulse Width
        PWM0TCR = 0x00000009; //PWM Start
        while(1)
        if ((T1IR & 1) == 1)
                        if(motor == 0)
                                PWM0MR2 = 120000; //Set new speed
                                PWM0LER = (1<<2); //Change to new speed
                                motor = 1; //Motor On
                        else
                                PWM0MR2 = 0; //Set new speed
                                motor = 0; //Motor Off
                        T1IR |= 1; //Clear timer0 interrupt flag
Thanks, Joe
