I would like to do conditional compiling and include different C files based on the hardware being used. For example:
#ifdef HARDWARE_MODULE_1
#include "hardware_module_1.c"
#endif
#ifdef HARDWARE_MODULE_2
#include "hardware_module_2.c"
Everything works fine this way only debugging becomes a problem. Breakpoints don't work correctly when placed in the C file that's included that way. The program ends up breaking somewhere else random in the code (different C file altogether) When I manually add file to the project everything seems to be working fine. I'm using uVision V4.60.6.10
I think you would find it easier to set up multiple targets and including one of those two files in each.
Multiple targets is most probably the best route.
A different route is to instead have the C files look like:
hardware_module_1.h:
#ifdef HARDWARE_MODULE_1 void hardware_module1_stuff(void); #endif
hardware_module_1.c:
#include "config.h" #ifdef HARDWARE_MODULE_1 #include "harware_module_1.h" void hardware_module1_stuff(void) { ... } #endif // HARDWARE_MODULE_1
main.c:
#include #config.h" #ifdef HARDWARE_MODULE_1 #include "hardware_module_1.h" #endif #ifdef HARDWARE_MODULE_2 #include "hardware_module_2.h" #endif ... #ifdef HARDWARE_MODULE_1 hardware_module1_stuff(); #endif #ifdef HARDWARE_MODULE_2 hardware_module2_stuff(); #endif
