Keypad problem
I use ATMEL 89c51 microcontroller with keypad 4x4.
My problems is that my 1st row contain 1 2 3 A
it display 1 2 3 A for every row
i checked the code on proteus8 its working fine
and also on 8051 kit its working fine.
but on my PCB its showing 1 2 3 A for every row
in column wise under 1 all are 1 and under 2 all are 2 and so on.
I checked the PCB by interfacing the PCB with 8051 kit's keypad and it worked and then i connected my keypad to the alternate port of 8051 kit it is working well.
but when i connect my keypad directly to the PCB it shows the problem again.What is the solution for it?
<\b>
