Common Code Elimination
cortex-m3 uVision 5.13
I recent had to up the optimization level on my project to level 2 because my code size was too large for my target memory. In doing this I found that it seems to be doing common code elimination where valid routines are not being compiled/linked into the image.
This has caused some routines to be practically wiped out because another is very similar but has some differences. I guess they were common enough for the compiler to decide to get rid of one of them.
I have been Googling and searching everywhere for a way to turn off just the common code elimination but cannot find anything that I can use with uVision.
There is a C51 pragma to change the optimization level to stop this on a file by file basis but the uVision compile causes a error.
There must be a way to turn this off. I understand it is trying to save me space but it is also changing or in some cases eliminating functionality.
Does anyone know of a pragma that will work or something I can do?
P.S. of course this happens 2 days before a major delivery on a weekend!!
