hi everyone, please help me to solves this problem! when i installed the program, pack installer requires me to download and install a lot of packs. however, the installer can not download the packs. althought, my internet connection is very good! the fail what is shown:
"file download failed reason: object not found"
It looks like something is changing or something has been broken on http://www.keil.com/pack/ because according to this documentation: www.keil.com/.../_create_pack_publish.html there are missing .pdsc files ( error 404 ) and that is why pack installer can not download DFPs.
If you need to use some DFP you can download them manually from http://www.keil.com/pack and import into Keil uVision IDE, see here for more details: http://www.keil.com/support/docs/3646.htm
Likewise - Check for updates Cannot download file http://www.keil.com/pack/ARM.CMSIS-Driver_Validation.pdsc: Object not found Cannot download file http://www.keil.com/pack/ARM.CMSIS.pdsc: Object not found Cannot download file http://www.keil.com/pack/Hitex.CMSIS_RTOS_Tutorial.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.ARM_Compiler.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.BulbBoard_BSP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.CM4xx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EB_TMPM369FDFG_BSP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32GGxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32Gxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32HGxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32LGxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32TGxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32WGxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EFM32ZGxxx_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EZR32LG_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.EZR32WG_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.FM0plus_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.FM3Basic_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.FM3HighPerformance_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.FM3LowPower_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.FM3UltraLowLeak_DFP.pdsc: Object not found Cannot download file http://www.keil.com/pack/Keil.FM4_DFP.pdsc: Object not found
<and so on>
Check for updates error: Cannot download one or more files Refresh Pack descriptions
thank you! i solved it.
This is just a test as it was before the server upgrade impossible to post links to youtube.
www.youtube.com/watch is a presentation that I did at ARM TechCon in 2014. Watch the video to get an impression of the features of CMSIS.
another test: www.youtube.com/watch
