How can I make UV5 to automatic generate a its default scatter file?
Build the project?
Doesn't it typically auto generate a .SCT in the output directory when "Use Memory Layout from Target Dialog" is checked? You might want to copy that into the Project or MDK directory, and change path using the "Scatter File" buttons.
Indeed... many thanks
