RTX timing change
I am really surprised that with the latest version of RTX that Keil has changed the functionality of the millisecond parameter to delay functions.
See
http://www.keil.com/support/docs/3766.htm
It sees that now the delay parameter is having 1 added to it in the latest version of RTX.
This is a significant functional change that I would have thought would not have been implemented without reaching out to the community of users. This change breaks a ton of existing code that relies on polling intervals of the tick frequency.
I regularly have threads that implement a 1 ms polling of hardware devices. This is implemented as a simple delay of 1 ms. Granted the first call to this delay function may return in less than 1 ms, but after that it is consistently 1 ms in duration. With the changes I don't believe that I will be able to poll at the tick frequency of 1 ms, it would be 2 ms. It seems to me that minimum polling time has been decreased to 2 times the tick frequency with the latest version.
I would strongly encourage KEIL to put back the original functionality, but I was wondering if others had the same concern.
  • I agree that the API shouldn't try to hide the user from the sample point synchronization by an obligatory add of 1 to the requested delay value.
    It should be up to the individual developers to add that extra tick.
    Right now, you changed the behavior to "always" give a too long delay. It is quite strange that existing software should need to add a -1 just to get around a design change, when it's the users with lacking experience that should really learn about sampling theory.
    Changing the behavior of an existing API really is a no-no! Especially when the new design always produces a delay that is off-by-one. A "busy-loop" with delay 10ms will no longer manage 100 iterations in a second, since each delay will average 11ms. So 91 iterations instead of 100.
    You introduced medicine with worse side effects than the sickness you wanted to cure.
