I am trying to add a custom tool in the UVision IDE 4.73. Running a tool works perfect and I have 2 situations that influence my script output behaviour. In the "Customize Tools Menu" :
1) - "Run Independent" enabled causes all my output to be displayed in a terminal window nothing is shown on the "Build Output" 2) - "Run Independent" disabled causes all my output to be redirected leaving a blank terminal, however after the script has finished all output of the script is shown in the "Build Output" window.
My question: - Is it possible to run a script like in situation 1 ("Run Independent" enabled) and have the output printed in the "Build Output" like in situation 2? - Is there a dedicated file handle which can be manipulated?
I know that everything which is printed on the "Build Output" is also saved in a *.build_log.htm file but I am guessing that it is only updated after the process ends.
Thanks in advance,
