Calltree problem
There is a strange behaviour of the linker concerning the calltree!
Look at this simple code:
void Function1()
	int a;
void Function2(void (code *fptr)(void))
	int b;
	fptr();
main()
	Function2(Function1);
Function1 gets called from Function2 via pointer. Both functions declare a local variable (a and b).
The linker LX51 produces this calltree:
FUNCTION/MODULE              BIT_GROUP   DATA_GROUP
--> CALLED FUNCTION/MODULE  START  STOP  START  STOP
?C_C51STARTUP               ----- -----  ----- -----
  +--> ?PR?MAIN?MAIN
MAIN/MAIN                   ----- -----  ----- -----
  +--> ?PR?FUNCTION1?MAIN
  +--> ?PR?_FUNCTION2?MAIN
FUNCTION1/MAIN              ----- -----  0008H 0009H
_FUNCTION2/MAIN             ----- -----  0008H 0009H
I think that's not correct, because Function1 is not called by main() !
As a result of this calltree the linker locates the variables a and b to the same address!
      00000008H   SYMBOL    DATA     INT       a
      00000008H   SYMBOL    DATA     INT       b
As workaround I manipulated the calltree via linker options. Any other ideas ??
Bernhard
