How do I locate a constant variable at the end of code area using the Extended Linker ( LX51 ) ? In myfile source, my constant table is declared as: unsigned char code MyTable[10]= { ... } I would like to locate this constant table (by the corresponding segment at the end of my ROM). I use a Philips chip that provides 96kb of ROM mapped from 0x800000 to 0x817FFF. I use the ROM(HUGE) option in compiler and my application is not a banked one... I try with: - ?CO?myfile(0x817000), i have the L108 linker error - ?CO?myfile(^0x817FFF), i have the L108 linker error Could you help me?
Try: ?CO?(C:0x817000) Stefan
With ?CO?myfile(C:0x817000), i have the following linker message: - ERROR L205: CONSTANT TOO LARGE? What does it means? I cannot locate a constant table outside 0XFFFF address, so only in the first 64kb of ROM? This a chip limitation? Fell free to challenge this! Thanks.
Tony, ?CO? stands for CODE segment/constant. It sounds like you have something declared in code, ex.:
myfile.c char code dummy[4]; ...
myfile.c const far char dummy[4]; ...
80001BH 80001EH 000004H BYTE INSEG HCONST ?FC?MYFILE
817000H 817003H 000004H BYTE INSEG HCONST ?FC?MYFILE
Thank you Alex, It seems to be more clear for me!! But on my example i cannot use const far declaration but only far like this: myfile.c far char dummy[4]; So, in map file i don't find ?FC?myfile segment but ?PR?myfile....Why doest it means? In spite of, could i locate the new ECODE segment at the end of my ROM? Why i cannot use HCONST classe? Thanks you, TONY.
In fact, i can use const far type by declaring my table in HCONST by the following way: const char far dummy[4]; With this, i find a ?FC?myfile segment in map file and i can locate it at the end of ROM....OK for this step! But, what about a table of functions declared as below in a source file: code void (void * TableOfFunctions[]) In the same way, i would like to locate also this table at the end of ROM? Can i consider this a table as CONSTANT table and could i move it in HCONST segment? Thank you for the application notes (160) that you send me!
